Accelerated rolling surface fatigue (L10) testing
geesaman.d
360
I'm trying to study the vibration of a machine with antifriction bearings (mostly taper roller) that generally lives 5+ years before reaching rolling surface fatigue failure. Unfortunately I may not have a set of suitably worn bearings to harvest for this test study.
Is there a relatively valid way to accelerate it? I've considered indenting the rolling surfaces on the bench using sandpaper and a peen hammer, or preloading them heavily to make them wear within the time of my testing.
Another question: for taper roller bearings that are set slightly loose (say .003" factory endplay), how much additional endplay is reasonable to simulate bearings that have lost material to rolling surface fatigue?
Thanks,
David
The loss of material during a fatigue failure is in the form of pitting. The clearances shouldn't change as material loss is localized until it becomes severe.
I don't really understand your goal of pre-failing a bearing. Most vibration analysis starts with a baseline of a good machine and any deviation from the baseline indicates failure.
We make gear reducers and we are testing monitoring equipment. We have an endless supply of like-new machines to monitor but we don't have 20 years to wait for end-of-life.
Well if you have access to the bearings, then I guess you might be able to poke a tool between the rolling elements on either side of the cage to scratch either the inner or outer race (or rolling element themselves for that matter, fatigue spalling can occur on any of these locations).
As Tugboat mentioned, people in industrial plants monitor for rolling bearing defects using vibration quite well without needing any such experiments. Trending plays a role along with comparison to similar units. There's a lot of specizlized signal processing that can be applied towards detecting bearing defects. For example by trending CSI Peakvue Max Peak Wave you can be alerted to a defect long before it would affect the velocity overall. Further analyssis of peakvue and other spectra could help confirm the diagnosis and evaluate the severity. Sorry if I'm telling you what you already know. It's not clear what you're trying to accomplish.
(2B)+(2B)' ?
