Accelerating a Mass with pneumatics
wob2015
7
Hey all,
Not sure I am posting in the right forum, but here it goes.
I need to simulate a mass falling from 10 meters, but only have about a meter of height to do it in. Therefore I need a method of accelerating the mass to a certain velocity, and then release the weight halfway through its travel so the mass is in free-fall at the time of impact.
The first thought that comes to mind is a pneumatic system with a magnet as a release. As long as the stroke of the piston is shorter then the 1 meter height, it would essentially give the weight a "boost" at the beginning of its drop. However i do not know if this is possible with pneumatics. Has anyone heard of a piston that would be capable of this kind of velocity? it is a 7 lbs mass.
OR if you have another method of how to accelerate a mass with these conditions, id love to hear about it.
Thanks,
Wes
Pnuematics for motion control are typically not a good ideal. Repeatablity and control using air (compressible gas). If you want to accelerate a mass, maybe using a timing pulley and timing belt arrangement might be better. This hooked to a motor with variable speed drive, might do the trick. If you need more control and precision with acceleration then hook the system to a servo drive.
Rich....[viking2]
Richard Nornhold, PE
A flywheel?
Since you will be accelerating faster than gravity you would not need to release only at the bottom of stroke. I was thinking of a punch press design. You may need the ram to quickly reverse stroke and get out of the way of any bounce. Have the down stroke of the ram trigger a mechanical release of the object at begining of stroke. Vary the speed of flywheel as needed to tweak impact velocity.
Or just cut a hole in the roof....
Barry Payne, Titular Despot Emeritus
I'd just use a big compression spring with a pin release. Easy, adjustable (put a screw behind a plate at the top), and cheap.
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
Thanks all for the posts! Ill look into them further.
Consider a simple lever arrangement.
Pin the lever at one end and locate a weight of ten times (or 100 times if this varies with the square ? ) at 10% of the lever length from the pin. This will produce a 10 g acceleration. Provide a strong "stop bar" at the end of the lever at the opposite end from the pin at the height tou require for the "free fall" to start.
