Turn_of_the_Screw
Hello Everyone,
We are currently trying to design a conveyor that will take a panel (180" x 72" x 1" and 800 lbs) from a constantly slow-moving conveyor (10 feet/minute) to a constantly fast-moving conveyor (300 fpm).
- The only way I can think to do this is by putting a secondary conveyor (as long as the panel) in between the slow and fast conveyor.
- This conveyor will need to run at a slower speed until the panel is on it completely.
- Then the conveyor will need to accelerate the panel to a faster speed.
- The length of this conveyor would be determined by the length it takes to accelerate the panel to a higher speed (presumably the size of the motor would determine this)
- After traveling at a faster speed, the panel would need to slow down again and eventually stop. I have no idea how we would slow this down other than letting it run out on a gravity conveyor.
Does anyone have experience designing systems that accelerate and decelerate products like this? The biggest problem I have is getting a motor, drive, and roller combination that will do both 10fpm and 300fpm.
Thanks in advance for any advice.
Chris
Chris
