Shrink fit of a stainless ring onto a shaft 7
Tiogar
1
Hello all,
I'm working on a new procedure at work (machinist/welding), and I've gotten conflicting answers on the formulas I need. I just started a ME program, but we haven't covered this yet.
I'm trying to shrink fit a stainless steel ring onto a stainless shaft, rather than us welding it up and machining it down.
The OD of the ring is 120mm, with an ID of 114mm and a width of 7mm. The shaft is 114 mm, with no ID. I'm trying to do the largest shrink fit I can, without causing materiel failure in the ring.
I can do the calcs for how strong the fit is, but I'm having trouble finding the calc for the max interference fit I can have without causing the ring to fail. It's a non-load bearing part. It's there to act as a corrosion barrier.
I've seen online calculators, but I'd rather know the math and theory behind it, if anyone can point me in the right direction.
Thanks!
Jeremy
Stress eng
Can you please see provide an excel spread sheet. I did give you a star
mfgenggear
I would gladly provide a copy, but, sorry to say, I don’t use Excel. I produced the template using Mathcad.
