I have been reading recently about a phenomenon called acceleration head. It seems to apply only to reciprocating pumps. My question (s):
If you had a glycerin-filled pressure gauge at the reciprocating pump inlet and another gauge at the booster pump discharge could you see the pressure difference? I would assume the difference would be larger than the difference due to friction losses. Would the glycerin act as a filter and mask the true magnitude? I'm wondering if this might account for cavitation in the reciprocating pumps even though we think we should have good quality fluid at the inlets.
I have heard cryogenic pump manufacturers talk about the need to mount pumps close to the supply vessels. Now I think I see why.
Thanks for any thoughts or insights.
