My customer wanted us to use an accelerometer to get the curve of the velocity over the position.
We used a 3 axis sensor, with analog output. Here we used a 12 bit ADC.
Now all the effort has been done, but we cant get the exact position of the movement, which is a movement in just one axis. Customer may want to bring new axes in future as well. As we did integration over the acceleration and then over the velocity, we get very diverse results, but none of them matches by far with the real distance which was carried out.
Especially if you put two sensors on the same movement they will surely give very different results.
Now customer wants dearly a result for the position with max 10% error.
We are a little bit clueless what to do to get the exact position, we even envisage in using a different sensor with more precision. But still there would be error at integration, which cant be avoided.
Has anybody some experience with getting position out of acceleration?
I am really thankful to any suggestion.
Regards, Ina
Regards, Ina
