XL83NL
- Mar 3, 2011
- 3,109
Im having a problem getting access to old(er) ASME IX interpretations, more specifically; IX-89-91 / IX-83-06 / IX-83-22 / IX-83-104 / IX-83-172.
Are older interpretations freely accessible through the ASME webs? I could only find links to later editions (I believe starting from 2004).
The question I'm having is on the use of consumable inserts in B31.3 pipe welding. Above mentioned interpretations may provide an answer, but they may also not as I dont know there content, so Ill take a shot.
Small bullets (round solid pieces of bar with the same chemistry as both base metals) are used as tack bridges in the root of GTAW welding, by positioning 4 at each quarter inside the V-groove (i.e. not on the top surface of the pipe) and tack welding them.
It's small dia piping, there's no welding from the inside. Later they're cut out so the root pass can be completed. Are such bullets to be considered as consumable inserts as defined in B31.3?
They're (obviously) not fully consumed/melted in the welding process, however a small part of the bullet is consumed in the V-groove due to the bridge tack weld.
My reasoning in a discussion, as I believe theyr'e consumable inserts, is that a (be it very) small part of the bullet is consumed/melted into the base metal, thereby allowing it to change the base metal properties.
Hence it should be demonstrated by a qyualified WPS [B31.3 para 328.2.1(e)] they're suitable.
