Jan 29, 2021 #1 mekafime Mechanical Aug 14, 2015 88 PE Hi guys, i need to design an accessory used in bobcat for soy grain the accessory is this ... Will you have drawings, or will I calculate that plate to adapt the beam?
Jan 29, 2021 #2 SnTMan Mechanical Jan 22, 2005 6,782 US You calculate it. Regards, Mike The problem with sloppy work is that the supply FAR EXCEEDS the demand Upvote 0 Downvote
Jan 30, 2021 1 #3 hydtools Mechanical Apr 4, 2007 3,265 US Or you buy weld-on plates. For example: https://www.worksaver.com/adapter-a...uFaqVRV2S0vQYM5L2Y8Dyv23pT9P4cCBoC1PAQAvD_BwE Ted Upvote 0 Downvote
Jan 30, 2021 #4 hydtools Mechanical Apr 4, 2007 3,265 US See also the SAE standard. Ted https://files.engineering.com/getfile.aspx?folder=9f18ff2f-fc5e-4d6e-89f5-a36c1c63c4f6&file=Sae_j2513.pdf Upvote 0 Downvote
