Accoerconsole for batch publishing
durga_k
1
Hi All,
Trying to use accoreconsole.exe for batch publishing of .dwg file to .pdf
The script is running fine, however the issue I'm facing is, it generates a prefix to every pdf generated. Eg 56GF-Model.pdf
The ideal condition should be 56GF.dwg to 56GF.pdf.
Attached is the .scr which I'm using.
Any suggestion thanks in advance
 https://files.engineering.com/getfile.aspx?folder=76b8d3df-b0ed-4da6-a4d2-e5a23b7463da&file=GenericWorker_pdf.txt
