engjg said:
It seems regardless of whether you evaluate the design displacement or not they send you to 18.7.6 which requires shear force calculated from Mpr?
Yeah, I read it the same and have always found it a bit surprising/punitive. Apparently a gravity column in stiff shear wall building will get the same capacity shear design as a gravity column in a moment frame building (and a SMF for that matter). That said:
1) Shear failure is brittle.
2) Upper bound, drift induced column shear demand is pretty damn hard to estimate accurately.
3) Tightly spaced column ties aren't going to be a huge dollar item in the as-buit cost of most buildings.
4) Gravity columns do perform a rather important function. You know, keeping folks from gettin' squashed to death and all.
Designing wallumns (high aspect ratio columns) for Mpr in a flat slab system would punish their shear design something fierce. But, then, that might be a good thing based on past wallumn seismic performance. If your seismic shear demand is small, it's not such a big deal. The shear demand when combined with gravity load may not even result in a net shear reversal in some, marvelous cases.
Agent666 said:
Also can anyone explain to me in layman's terms what ACI 318-14 18.6.5.2(a) means?
I agree with Agent666 on the straight forward application of that clause. I would add that one should recognize that seismic shear demand is cyclic and reversible. And, compared to monotonic, gravity shear demand, the cyclic condition is much worse. The repeated opening and closing of shear cracks grinds down the aggregate interlock and ratchets the crack apart such that whatever interlock remains isn't very useful. Since much of Vc is dependent on aggregate interlock, we deem it reasonable to ditch Vc in cyclic shear scenarios and, instead, only rely on the concrete and reinforcing acting together as a truss mechanism for shear resistance.
So, in abbreviated, layman's terms: when a large portion of your shear demand is cyclic, reversible seismic shear... don't count on having Vc available.
