zurch1818
- Feb 16, 2015
- 37
thread507-499654
Expanding this referenced thread, how have people been handling this for existing structures that weren't designed with this provision in mind? To me it seems really odd to have to say a structure that was completely fine before now is screwed over when the gravity loads (5%) and lateral loads (10%) exceed IEBC limits?
For example, I'm working on an existing pan and joist building from 1983 where some small rooftop telecommunications equipment is proposed to be installed. I'm exceeding the gravity loads by 8% from the original condition. With where I'm putting the loads, moment is checking out (although starting to reach its capacity) but shear is now blowing up (even with the 10% bump with 8.8.1.5). Shear is also blowing up in the original condition. If I use the old provisions, shear will check out in the proposed case.
Since it is a pan and joist system, there really isn't room for stirrups (even if there was some way to install them in a joist that is only 4" wide at the base).
