ARS97
- Feb 24, 2010
- 160
I'm designing a rectangular concrete tank and I'm working through the seismic loads per ACI 350.3-06. I have the various dynamic forces calculated from Section 4.4.1.....Pw', Pr, Pi and Pc. What is stumping me is the consideration of "Peg" in the base shear calculation. "Peg" is the lateral force on the buried portion of the tank due to the dynamic earth and groundwater pressure. Chapter 8 is referenced for Peg, but it doesn't appear to include any further details, except for resultant locations.
I know the static lateral pressure from the soil and groundwater. In this design, the tank is being designed for groundwater at the surface (21' depth). The lateral pressure will be due to the buoyant weight of the soil (120 pcf - 62.4 pcf = 57.6 pcf = 57.6 psf/ft) and the groundwater (62.4 pcf = 62.4 psf/ft). This will be assumed to produce a simple triangular pressure distribution (total of 120 psf/ft) over the 21' depth. This equates to a static pressure of 2,520 psf at the wall base.
Is Chapter 8 simply stating that you are to use the full static load as the dynamic load (Peg)?
