Acker Vane Shear Equipment
OhDanny
Geotechnical
Jul 5, 2006
Hi does anybody have any experience with using the Acker Vane Shear equipment. Is it suitable for rotary drilling machines? I understand that is better for percussion drilling machines as their legs are more spread out.
Cheers
I have successfully used the acker vane shear equipment that mounts on a hollow-stem auger. Since it is for soft soils, you don't need much resistance. The vanes will bend before the auger ever turns.
The only issue we had was fabricating a custom mount for use with our hollow stem augers. If I recall correctly, it cost about $200 for a local shop to do using an old auger drive cap.
Jeff
