ACME thread screw and nut - torque and stresses
Hanson Gill_1983
21
I'm calculating the stress acting on an acme screw and thread (see image attached). The screw is rotated by means of the handle to raise under a load 25000lbf. I have calculated the torque required to raise this load which is 250 ft.lbf, and found the torsional shear stress of the screw part.
Now what are the other stresses i should calculate?especially for the nut. please let me know. if you have any formula ref it would be great. thanks.
 https://files.engineering.com/getfile.aspx?folder=8e41d9f9-c07e-4b9c-bafc-e947ab2c5dcd&file=ACME_Thread_screw_and_nut.jpg
Buckling?
Engineering is not the science behind building. It is the science behind not building.
Is there a good reason you're not using a pre-engineered screw and nut? Go with a design that has already passed by all the land mines. There are LOTS of commercial options available.
