Hello All!
My employer has started quoting treatment of various gas and water streams that involves the use of deionized water. I don't have any experience using DI water, but understand it is corrosive and a leach agent. A couple of the systems I am laying out are small with low flow rates and I'm thinking of using acrylic flow meters for the DI water side of the system. The pressures are 60 psi max and temperatures @ 80 deg F max. My main concern is leaching of something into the DI water from the acrylic. Does anyone have experience using acrylic with DI water? Many thanks!
