Activate Main Top Node product in assembly
NaWin55
98
Hello all
i am trying to create a macro to activate top main product of a assembly
i tried Product.Activate didnt work
catia.startcommand "frmActivate"
didnt work
is there any way
when i run the macro the mainproduc1 should be in Blue color means that is the active editing product in tree
refer image
you need to select the node first, and then use the StartCommand.
Code:
Sub CATMain()
Dim myDoc
Set myDoc = CATIA.ActiveDocument
Dim Selection1 As Selection
Set Selection1 = myDoc.Selection
Selection1.Add myDoc.Product
CATIA.StartCommand "FrmActivate"
End Sub
regards,
LWolf
