Is it possible to scale the analog output to a lesser value than the full current of the CT's. I am using a Acuvim-II meter with 400 amp CT's I would like to scale the analog output down to 60kW total power, without loosing resolution.
I'm using the instrument to monitor and compare the power consumption of 60hp blowers using inlet valve throttling vs VFD.
