bj7777
Automotive
- Feb 1, 2019
- 33
hello
I'm using an MSC model called mini-Baja that has been built in Adams/Car 2005 and anlysing it in Adams 2018 . Mind you , the files are ready on MSC Adams official site .
problem is that I can't get the exact results from Adams/car 2018 Postprocessing …( Minute differences ) the parameters I want are vertical chassis acceleration and chassis longitudinal velocity
no matter what I did from changing units to changing solver integrators ( to the best of my knowledge ) was nigh on futile ...
can you explain how this happens ? is it a matter of changing Solvers Integrators because I have tried almost all of them ? was there something in Msc /Adams car back in 2005 that is changed in 2018 ? if so what can i do to get the exact results ?
my results are very similar to the results of the model in 2005 but with minute differences ? what is the reason of those minute differences ?????
FYI : i'm running the model in File Driven Events and the Baja vehicle model has post-made files for that ...
thank you very much
thank you very much
