ADAMS Constant Radius Cornering simulation fault 1
konrad.stachon
Student
PL
Hello, I keep running into this error message when trying to set up Constant Radius Cornering simulation. I was ok, before I changed CM location.
---- START: ERROR ----
At time 7.708098512E-01 the integrator is unable to start/restart. Possible Causes:
(1) The accuracy required for the numerical solution can not be attained.
Relax (increase) the value of the acceptable integration ERROR.
(2) Incompatible redundant constraints, a lock up, or a bifurcation
situation. The latter two indicate a mechanism design problem.
(3) The system includes a zero (or relatively small) mass on a part with
an unconstrained translational degree of freedom.
Make sure you have mass on all parts with translational degrees of freedom.
(4) The system includes a zero (or relatively small) inertia on a part
with an unconstrained rotational degree of freedom.
Make sure you have inertias on all parts with rotational degrees of freedom.
(5) An Adams element has a function expression that equals exactly itself.
For example,
SFORCE/id1,I=id2,J=id3,ROT,FUNC=SFORCE(id1,jflag,comp,rm),and
DIFF/id4,IMPLICIT,IC=0,FUNC=DIF1(id4).
Similarly,
VARIABLE/id5, FUNC=VARVAL(id5)*TIME
equals itself at 1 second. Avoid setting an Adams element equal to itself.
---- END: ERROR ----
Dynamic Solution stopped.
End Simulation
Simulate status=-124
SIMULATE command failed for minimaneuver: STEADY_STATE
Aborting Execution.
Adams Solver (C++) run terminating due to STOP requested by user.
Termination status=-995
Terminating Adams Car usersubs...
Finished -----
Elapsed time = 10.93s, CPU time = 10.13s, 92.63%
Simulation is complete.
Thank You very much Greg for quick answer. The animation looks strange at this case, because front wheels have fallen off xD. I changed step size, and turn radius a little and for now it works.
Konrad
PGRacing Team
Sadly I've problems with CRC again. For now the simulation works but it looks strange. Below You can see the steering wheel position and simulation parameters. I tried to change simulation error and Hmax parameters but it didn't work. If You have any idea what could be wrong it will be really helpful.
Others dynamic events like J-turn or mentioned swept steer works good. Wheelbase: 1280mm Reduction ratio: 5.25E-02 (4,71" / 1 rev)
I tried to untick Quasi static skidpad setup, but nothing changed. Steering ratio: 3.85
To be honest I'm not sure what you mean when you write "understeer number", but attached bellow slip angle's graph looks fine I think. The speed was 60 km/h.
Calculation based on a tire cornering force graph gave 1,7 deg slip angle for the front axle, which is a similar result to simulation. For the rear axle slip angle is slightly higher and it is 1.8 deg, which is a big difference in comparison to simulation. Weight distribution is 48% on the front and 52% on the rear axle.
Ok, I try in the evening and let You know.
Thank You very much for help.
I tried different tires, but the result in CRC is still the same. Good news is that I found a mistake in tire parameters and for now slip angle values are similar to simple calculation for both axles.
OK, so that eliminates the most likely contender. Have you got friction statements in your model? other than that, the usual procedure is to start from a model that works, and switch in your new subs until something breaks.
Cheers
Greg Locock
