Adams Tire: Friction ellipse
voo34
Automotive
May 19, 2021
1
In MSC Adams Car - Tire manual, to calculate Fx and Fy for combined slip conditions, this equation can be used:
I coded this equation in MATLAB, but there are some of points i cannot understand:
1- My road's friction coefficient is 0.37. How can i handle this value? Is it mu_x,max and mu_y,max? (mux_max = muy_max = 0.37 ?)
2- What is mu_act?
Do you have an example for this formulation?
Thanks a lot!
Road friction is handled in the rdf file, for example. As to the rest, it is probably explained near the bit you quote.
$---------------------------------------------------------------------MDI_HEADER
[MDI_HEADER]
FILE_TYPE = 'rdf'
FILE_VERSION = 5.00
FILE_FORMAT = 'ASCII'
(COMMENTS)
{comment_string}
'flat 2d contact road for testing purposes'
$--------------------------------------------------------------------------UNITS
[UNITS]
LENGTH = 'mm'
FORCE = 'newton'
ANGLE = 'radians'
MASS = 'kg'
TIME = 'sec'
$--------------------------------------------------------------------------MODEL
[MODEL]
METHOD = '2D'
FUNCTION_NAME = 'ARC901'
ROAD_TYPE = 'flat'
$-----------------------------------------------------------------------GRAPHICS
[GRAPHICS]
LENGTH = 2000000.0
WIDTH = 1000000.0
NUM_LENGTH_GRIDS = 200
NUM_WIDTH_GRIDS = 100
LENGTH_SHIFT = 20000.0
WIDTH_SHIFT = 0.0
$---------------------------------------------------------------------PARAMETERS
[PARAMETERS]
MU = 0.37
$-------------------------------------------------------------------------RESSYS
[REFSYS]
OFFSET = 0.0 0.0 0.0
ROTATION_ANGLE_XY_PLANE = 0.
Cheers
Greg Locock
