ADAMS View: Export numeric data automatically
Lucas_M
Bioengineer
Jun 4, 2021
I am currently a high number of ADAMS/MARC cosimulations. Everything works fine but after each simulation I have to export data manually. (File -> export -> Numeric Data, ...)
After that, I am loading those data on Matlab and I am doing some calculations.
I wonder if it is possible to "automatize" the export of numeric data after each simulation instead of exporting them manually each time. If you have any suggestions that might be more efficient, I will glad to hear them.
(I know it is a basic question but I tried to found a solution on the internet and here but I failed. Perhaps I used the wrong keywords)
Lucas
I don't use View much but suggest you write a macro to do this. I must admit I'd have thought writing a strip cart to txt would have been a selectable option. It should also be possible in the acf, possibly using this command output_control set output
Cheers
Greg Locock
Thank you, it is working. I achieve to have something.
It is possible to write Macros in .cmd files or record them (recording is much easier). Everything is well explained in ADAMS view help (-> macro)
Lucas
