adapting BSP to Metric
roman_i
I have spent a lot of time looking for appropriate adapters to get from 1/2" BSP female connector on the end of a hand pump to M33x2 male on the top-up valve of a ground source heat pump manifold. I am dazed and confused by a world of options, no combination of which appear to do the job. Can anyone versed in the world of hydraulics please help me with a solution that will allow me to use the pump I have to top up my GSHP fluid? The solution need only withstand 1.5 PSI. I am willing to remove the existing 1/2" BSP female connector on the end of the pump's hose and replace it with something metric but the metric thing I replace it with has to fit on the existing hose that the 1/2" BSP connector is currently attached to.
Many thanks in advance
roman
Google Parker 4300 catalogue. You will find what you need in the adapters section.
You don’t need to buy them from Parker, but this catalogue will give you a visual reference and part numbers for what you need.
