We require source code to add menus to solidworks. This menu should run an application.
If this requires to develop an addin then how this addin can be created by using VB.
To use the scripting.filesystemobject object, you need to add a reference to the Microsoft Scripting Runtime library. If you are using a full version of VB, this is found under a very long list under the VB menus "Project --> References". This is also where you add references to the SW type library and the SWpublished library needed for addin functionality (i.e. menus).
