Add a title into patran windows using PCL
nekcorp
New member
FR
I would like to add a title (my title) into Patran Windows using PCL.
I looked for in the different manuals of PCL, but I have not found the function.
Can you help me ?
thanks a lot.
Hi, i am not sure but try this.
Go to Results Tab, select title (where you will find so many options like Primary result name, Secondary result name, etc..). Even you can type the customised text there. It will appear on the title. While doing , record a session file. You will get the function.
