Hello Everyone,
I have very intresting problem, and I can't find solution:
I add attribute to threaded hole:
In Part Navigator I can see this attribute:
And after I try find feature with this attribute, and I can't.
I look at the code, and I don't see an error.
Maybe somebody can help.
Best regards
MANok
Tc14
NX2006
Code:
Dim nXObject3 As NXOpen.NXObject = Nothing
nXObject3 = holePackageBuilder1.Commit()
holePackageBuilder1.Destroy()
Dim feature As Features.Feature = CType(nXObject3, Features.Feature)
feature.SetUserAttribute("EndType", -1, endAttr, Update.Option.Now)
Code:
Module AddEnds
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim theUI As UI = UI.GetUI()
Dim theUfSession As UFSession = UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Dim Body1 As Body
Dim Bryla As NXObject
Dim prompt As String = "Wskaż bryłę do której dodajesz końcówki"
If SelectSolid("wskaż bryłę", Bryla) = Selection.Response.Cancel Then
Exit Sub
Else
If TypeOf Bryla Is Body Then
Body1 = CType(Bryla, Body)
End If
End If
lw.Open()
For Each feature1 As Features.Feature In Body1.GetFeatures
lw.WriteLine(feature1.FeatureType)
'If TypeOf (feature1) Is Features.Thread Then
' lw.WriteLine("gwint")
'End If
lw.WriteLine(".GetFeatureName: " & feature1.GetFeatureName)
lw.WriteLine(".Name: " & feature1.Name)
lw.WriteLine(".IsInternal: " & feature1.IsInternal.ToString)
lw.WriteLine(".FeatureType: " & feature1.FeatureType)
lw.WriteLine(".GetType: " & feature1.GetType.ToString)
lw.WriteLine(".Timestamp: " & feature1.Timestamp.ToString)
lw.WriteLine(".Suppressed: " & feature1.Suppressed.ToString)
If feature1.FeatureType = "SIMPLE HOLE" Then
Dim exps() As Expression
Dim index2 As Integer = -1
exps = feature1.GetExpressions()
index2 = exps(0).Description.IndexOf("Threaded")
If index2 > 0 Then
If feature1.HasUserAttribute("ENDTYPE", NXObject.AttributeType.String, -1) Then
Dim attributeInfo As NXObject.AttributeInformation = feature1.GetUserAttribute("ENDTYPE", NXObject.AttributeType.String, 0)
lw.WriteLine(attributeInfo.StringValue)
Else
lw.WriteLine("no attributte")
End If
feature1.Highlight()
End If
End If
'lw.WriteLine("********************************************")
Next
End Sub
Function SelectSolid(ByVal prompt As String, ByRef selObj As NXObject) As Selection.Response
Dim title As String = "Select a solid"
Dim includeFeatures As Boolean = False
Dim keepHighlighted As Boolean = False
Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
Dim cursor As Point3d
Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
Dim selectionMask_array(0) As Selection.MaskTriple
With selectionMask_array(0)
.Type = UFConstants.UF_solid_type
.SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_SOLID_BODY
End With
Dim resp As Selection.Response = theUI.SelectionManager.SelectObject(prompt, title, scope, selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj, cursor)
If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
'----Other unload options-------
'Unloads the image immediately after execution within NX
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
'Unloads the image explicitly, via an unload dialog
'GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Explicitly
End Function
End Module
Best regards
MANok
Tc14
NX2006
