Add comma to drawing dimension - 10,000 instead of 10000
pnyro
CA
I'm hoping someone can help me toggle between the American and Canadian numbering standards. I want the dimensions in a drawing to have a comma to divide up the number, ie. 10,000 mm instead of 10000mm. I can't seem to find this under Options > Dimensions, where I thought it would be. Thanks.
Hey Chris,
Thanks for your response.
The "system separator for dimensions" only seems to apply to the decimal separator. If I uncheck the box I can change the decimal from a '.' to a ','. However I was hoping to put the ',' to separate 10 from the 000 in ten thousand. I've also checked my regional setting on my computer and it says numbers should be separated by commas. Do you know if there is a regional setting in SolidWorks, that seems to be the only other place that could cause a problem.
Caleb
I think this is difficult to do because it's considered bad practice. Europe (and I guess Canada) uses a comma to seperate the factions from the whole numbers where a period is used in the US.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Chris,
The OP is not talking about the thousands separator, not the decimal point separator.
Ten Billion vs 10000000 vs 10,000,000,000
Ten Thousand vs 10000 vs 10,000
Ten vs 10 vs 10.000 vs 10,000 (the latter 2 being shown to 3 decimal places)
The commas make the larger numbers much easier to read. Confusioon can arise when dealing with the smaller numbers.
eg. 10,000 (ten thousand) could be mistaken for 10.000 (ten to 3 decimal places) in some regions.
I agree that a comma should only appear in separating whole number from fractional component (where/when). It would be nice if SW had the option of perhaps putting a space between every 3 digits though, so ten million and one-half would be:
10 000 000.500 000
Easier to read and no creating confusion.
-- Me chE ng2 005
"Metric uses commas, inches do not. It's not specific to certain countries. "
Sorry Chris, that's not the entire story. Continental Europe tends to use commas for decimal places, regardless of units/application. The US & UK use 'dots/periods'.
This is why in 'scientific' circles I'm pretty sure the idea of having a comma or any other indicator every 3 places is out of favor.
I agree with Kenat and MechEng2005. I like having a separator every three spaces where needed for ease of reading, but a comma is right out. If SW could add a space if desired I think that would be a nice addition (heck give us the ability to put a comma there, who says we should be prevented from bad design). In the US we _always_ use a period to seperate the fractional component from the whole numbers regardless of units. If I see a comma and no period in a number I can usualy decide what is meant from context.
-Kirby
Kirby Wilkerson
For your information, Canada uses point (".") as decimal fraction separator, regardless of units. For example: $14.99.
Since when. Continentals use the comma where the English speaking countries use a period. I have never seen the comma mandated for metric numbers.
To answer the OP's question, it is possible to remove the <DIM> variable from the dimension name and insert the text 10,000. This is of course very bad practice because the number will not necessarily reflect the actual model dimension.
TOP
CSWP, BSSE
"Node news is good news."
There is always the option of over-riding your dimension, and manually putting in the number with the comma yourself (not really the best practice, but will give you your end result).
I just manually over-rode the dimension for now. I think I will just encourage the person who is asking for commas to use different units or not have the comma next time. We are a Canadain company I think we can stick with the accepted Canadian rules for numbers. Thanks for the help!
