Add-in list...
Bouke
107
I have been experimenting with add-ins and now if I look under tools->add-ins I have a very long list of add-ins wich don't exist anymore. Does anyone know how to clean this list??
There is no way (that I know of) to clean the list, without a clean reinstall. The only thing that would not show up would be progams or apps that you no longer have.
Like if you had Solidworks office and went to a version of just SW. You would have to reinstall and then the Toolbox, Photworks, Animator, etc... would no longer be an Add-in's.
Scott Baugh, CSWP [pc2]
If you are in the SW Forum Check out the FAQ section
To make the Best of Eng-Tips Forums FAQ731-376
But I would have to clean out the registery before re-install right? I've been looking in the registery and the add-in list isn't easily found.
Yeah, thnx, good link. But it is too bad it won't remove items from the add-in list if the items don't exist anymore.
If you copy the class ID from the registry, you can manually enter it in the input/combo box in the first form.
[bat]Due to illness, the part of The Tick will be played by... The Tick.[bat]
