milkshakelake
- Jul 15, 2013
- 1,173
I want to add 2 stories on top of a 4 story 12" thick red brick party wall. Foundations are rubble wall. The new stories will be lightweight (steel joists and plywood). Axial force calculations and foundation bearing capacity are all okay with the new loading. I've taken loading from both sides. I conservatively assumed f'm = 1500psi. I'm running new columns to take concentrated loads. Laterally, I have CMU walls in the short direction, and relying on the brick walls in the long direction. I've even done this once 5 years ago, and the building is still standing.
My question: Even if it meets code, is this a smart thing to do? Does anyone have real life "negative" experience doing this? Legally, if everything passes code, I should be okay. But I really don't want to kill anyone due to a trick of nature.
I typically make a new building within the building if I feel that the loads are too high, but here, everything seems within reasonable limits. And I see lots of big, old 6 story brick buildings. Not sure about their wall thickness, but knowing how cheap people are, they're probably 12".
