RabitPete
- Nov 24, 2020
- 109
When adding a thicker, reinforced footing in a middle of the existing PEMB slab, any pros and cons of tying new footing to the old slab with rebar dowels? There is a granular fill under existing slab, and it always makes me nervous, as excavation results in gaps under the old slab around the perimeter.
Also what are the thoughts on a vapor barrier? Add vapor barrier to the bottom and ignore sidewalls?
