I create a diameter dimension for a hole and would like to add the depth to the dimension using the depth symbol. Is this possible? When I select the "Insert text after" manipulator, the symbols can't be accessed. When I right click the dimension and select properties, the suffix text field under the "dimension text" tab is greyed out, because the diameter symbol is used as a prefix.
I could create a leader text note, but would prefer not to.
