ADDING BSP THREAD TO HOLE WIZARD
Robbo1971
Automotive
Nov 1, 2006
33
SolidWorks 2005
Is it possible to add BSP Threads to any of the Hole Wizard databaes?
I can't remember if it is in SolidWorks 2005 or not, but, insert a tapped hole (not pipe tap)using the DIN standard check for Straight Pipe Tap Type ("G" taps)
using the pipe taps, the BSI standards give you Rc series.
Again, I can't remember if this is the same in 05, I know this is how it is in 06 & 07.
CSWP
SolidWorks 2007 SP5.0/2008 SP0.0
2xDual-Core AMD OPTERON 280 / 8GB Ram
Quadro FX3450
3DConnexion SpaceNavigator
