Greeting,
I'm dealing with an existing residental building with masonry walls and RC slabs.
I figured there is a bearing wall in the middle of the slab span - load from this wall acting on a slab is pretty large.
Slab is only 140 mm thick and is not sufficient for current standards.
What can be done there?
Putting a RC/steel beam under existing slab will change bending and shear moments in the slab since we go from simply supported to continous beam.
I'm not concerned about bottom reinforcement in the slab but there is no reinforcement in the middle of the slab (the top zone) where is needed if I add a beam.
There will be some cracking at the top of the slab resulting enlarged bending moments in left and right field.
I'm not sure whats the proper way to solve this.
Hoping for some suggestions.
Tnx
Tnx
