adding portland cement to soil
drt
Geotechnical
Mar 15, 2002
13
0
0
When adding portland cement to a silty or sandy material, what is the effect on the shear strength. Obviously, the cohesion will increase, similar to a naturally cemented deposit but what happens to phi ?
Does addding portland cement to soil only increse the cohesion and the frictional component remains essentially unchanged ?
OR ?
It would seem that as the cement content increases, the material would begin to behave more like traditional concrete (stress independant) rather than a frictional material. Therefore, the strength of the soil would be determined using a test similar to how concrete is tested, unconfined compressive strength.
Your comments and/or references to technical publications would be appreciated.
Hi Drt.
I did recently soil cement mix.
4.5% cement content mixed with sandy silty soil gave me 200KPa cohesion and frictional angle 35 degrees. Effective value from CIU test.
80 kilogram of cement mixed with 1 cubic meter of this soil gave me UCS 2 Mpa.
