DoubleStud
- Jul 6, 2022
- 499
Hello gentlemen. I am not sure what would be the best detail. Lets say you remove a wall between kitchen and living room and replace it with a W10 beam. The beam will be placed right below the existing joists (and blocking between joists). How would you typically connect the beam to the existing joists? This beam will not be collecting lateral load and will be purely vertical load. Is it possible to just put the steel directly below the joists without nailer? What would be the cleanest or easiest way to do this if you have 2 scenarios. First scenario the steel beam will be covered with drywall. Second scenario the beam will be exposed.
