Hello every body,
For butt welding of material A283GrD thickness 22mm, we use FCAW process with E71T1-MJ filler metal with gas 20%CO2+80%Argon. UT is used for weld inspection and defects found are up to 3%.
Based on what we heard about this process, I have a doubt about its adequacy even if the UT results are satisfactory. Can somebody help me to know about the risk of this process against quality and if any failure can occure for pressurased items in service.
For exemple, can some types of lack of fusion produced by this process not be identified by UT?
Thank you
Thank you
