Ratty
Automotive
- Oct 29, 2003
- 5
Hello everyone, my first posting on this site! I'm hoping you may be able to help me...
I am designing a proximity sensor for use in an agricultural application. It is to be fitted outside the passenger cabin and must operate within fairly standard automotive specifications with the addition of:
Resistance to checmicals includes 20% aqueous mix of liquid lime and 7.5% NPK Fertiliser. Temperature specification is -40 deg C to +135 deg C and the sensor must be resistant to water ingress to IPx6 or better.
The eletronics in the sensor are contained in a plastic housing, material is syndiotactic polystyrene (sold under the name of Questra), and will be sealed by a lid of the same material. I was going to ultrasonic weld this joint, but we've run into process problems. Ultrasonic welding doesn't provide the exact location I need, so I'm looking into a field new to me - adhesives!
I've tried a couple of adhesive manufacturer's here in the UK, but both have shied away with little explanation. Does anyone have any advice on possible adhesives, suppliers or why the two I have tried want nothing to do with the idea?
