jochav5280
- Apr 21, 2008
- 79
Good Morning,
In regards to Section 11.4.5 of ASCE 7-05, would someone please advise of how one would adjust the Design Response Spectrum curve for a damping ratio other than 5%? I’ve had multiple contradicting statements such as, “the system R-value accounts for the damping associated with that structural system”, or “Table 18.6-1 should be used.” This is not clearly addressed in ASCE 7-05, as there is no reference as to how this curve should be adjusted. Table 18.6-1 obviously comes out of Chapter 18, which is for structures with a formal damping system, but would it apply to just regular structures as well? Does ASCE 7-05 address how to approximate the damping ratio or are these values generally just based upon a building being a steel (damping=2%) or concrete structure (damping=5%)?
A reference to ASCE 7-05 supporting your answer would be much appreciated. I've had (2) PHD's give me conflicting answers and depending on which way you go, the seismic forces could be substantially higher in the case of 2% damping per Table 18.6-1, which calls for increasing the spectral response accelerations by 25%, (1/0.8).
Thank you in advance!
Best Regards,
jochav5280
Best Regards,
jochav5280
