monopolystar
- Feb 11, 2015
- 7
Hi all , I'm just started using NX 8.5. Recently , Im doing simulation on two ring die. i would like to simulate stress analysis of the surface contact of an inner ring insert into a outer ring.
. As you can see from the image, the upper cylinder is the inner ring while the bottom cylinder is the outer ring. meanwhile, the diameter of inner ring is slightly larger than the hole of outer ring. Anyone could help please ? i would appreciate if you comment on this mail. thanks !
