mrpi
- Jun 22, 2008
- 80
I'm designing a custom motor for an industrial grinder.
This is a brushless servo motor intended to replace a synchronous AC motor.
Due to mounting constraints, I would like to install the cooling fan on the non-drive end of the motor shaft. All my previous experience is defense products in which the customer supplies a specified CFM of cooling air thru a duct to cool the motor.
I honestly have no idea what my options are as far as the fan blades themselves. Is it common to have a fan bent, cast, or injection molded for something like this? Then do you put them in a duct to characterize/verify the flow rate?
Motor speed is 6000 rpm or higher, so I was worried about using the fan that is supplied on the back of Baldor or other synchronous AC motors.
I'm designing the fin/heatsink arrangement on the motor housing, so I have control over the pressure drop.
Originally I was looking at using an axial fan, maybe even an automotive engine cooling fan, but I have no idea what kind of flow rate they produce. But I can find them rated to 10k rpm. It appears that most synchronous AC motors use radial fans and a curved shroud to turn the air so it blows down the body of the motor.
OD is in the 10~14" range.
My feasibility study shows I need around 200~300 cfm which equates to less than 0.25 inH2O pressure drop thru the fins.
Do I have a fan custom made?
Beat to fit, paint to match.
