Hi. I've got a powerscrew that is applying a compressive force of 25kN. The torque applied by the actuator to the nut to move the powerscrew is 200Nm. The shaft has a slenderness ratio of 124.
I've calculated using the Euler formula that I have a good x10 safety factor on buckling, but this doesn't take into account the torque applied to the shaft.
Does torque affect the critical buckling force? If it does how do I calculate the buckling force taking torque into account?
Thanks.
Hobbs101
Mechanical Design Engineer
Thanks.
Hobbs101
