AFXDataDialog
Jachidos
Materials
Jan 4, 2016
6
I'm currently trying to implement an AFXDataDialog box in Abaqus. Once the data is selected, I want it to choose between Ok, Continue and Cancel. Ok is if you already have all your data, Continue sends you to another box to select more data and Cancel... cancels the operation.
Ok and Cancel work perfectly fine already but I can't find how I'm supposed to program the Continue button.
He appears in the box but clicking on it doesn't do anything.
Does anybody have an idea on how to do it ?
Is the second box supposed to be in another class than the first one ? In the same one ?
Is there a particular way to program it ?
I recently tried defining my new form in a new class using the getNextDialog function. But it still doesn't work. I'm out of ideas, does anybody know how I should do ? :/
Here's my getNextDialog just in case :
def getNextDialog(self, previousDb):
self.dialog2 = newSet(self)​
return self.dialog2​
PreviousDB is useless here but the function takes 2 arguments. I'm not using previousDB because I want it to give the same box as many times as the user clicks on Continue.
