seetwo
Specifier/Regulator
- May 20, 2003
- 3
I am in the process of trying to decide if our company should switch from: a 60 ton water cooled condenser to: a 60 ton air cooled condenser.
My problem is that I have been unable to get a firm answer on whether a 60 ton air cooled condenser will give the same cooling power as our current 60 ton water cooled????
This if for an apartment complex in the state of Kentucky, USA. Temps typically peak in the mid 90's, occasionally 100+ degrees F. Average yearly humidity is 58% @ 1:00 p.m. to 81% @ 7:00 a.m.
We have been able to maintain a 42 degree chiller water temp pretty consistently. If we could get into the 38 or 40 degree range though, that would be a nice bonus, but that is not critical.
The existing water cooled tower is corroding and must be replaced soon.
It seems that in the long run, an air cooled condenser would be cost beneficial as there would be no water consumption and treatment costs. That seems to offset the increased electrical usage of the air cooled type.
We are using a chiller with 2 reciprocating compressors located indoors and the condenser nearby outdoors.
Any advise on the cooling power of the same size water cooled vs. air cooled condensers would be greatly appreciated.
Thanks. SeeTwo
tonnage
Thanks. SeeTwo
tonnage
