Hi, I'm having some issues with a centrifugal pump which is being used on a CIP tank.
Pump is 18.5 kW and is on a frequency inverter drive.
[ul]
[li]Tank capacity is 2,500L[/li]
[li]Pump suction pipework diameter is 3" NB[/li]
[li]Pump suction pipework length is ~ 1m[/li]
[li]There is a full bore ball valve in the suction line and a Y-strainer[/li]
[li]Liquid level is minimum of 1m above suction of pump[/li]
[li]Tank is vented to atmosphere[/li]
[li]Liquid is water at 20 degC[/li]
[/ul]
It's possible to re-circulate back into the tank, so I've been testing the pump using this route. I'm finding that at low speeds the pump runs quiet and no vibration. As I inch the speed up and it gets to around 35 hZ the noise and vibration starts. At 45 hZ it is extremely loud and vibrates a lot.
I've tried throttling the discharge by closing a valve - the noise seems to get worse.
When I throttle the inlet ball valve, the noise improves.
Have removed the filter basket from the strainer and didn't really make any difference.
I am wondering could this be an issue with vortexing in the tank? Is there any way to check this or remedy it?
The pump has several CIP duties, one of which is to supply liquid to a rotary spray jet at 5 barg. The flow rate at this pressure is 9,200 Litres/hour. So relatively low flow. The pump has to run at 45 hZ to generate this head and the issue of noise and vibration persists - despite the low flow. So then I wonder is it not vortexing and something else?
Thanks in advance.
[ul]
[/ul]
Thanks in advance.
