Air Heater
pimeng12
8
I would like to ask about air heater that consist of hot water element and steam element.
Is it air heater includes to shell & tube heat exchanger?
It looks like English is not your first language, pimeng12. Perhaps you could upload a sketch with labels to us, so we can see what you mean?
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
If you are trying to say air handler with heating coil (using hot water or steam), then a shell and tube heat exchanger is not used. The heating "element" looks very similar to a car's radiator.
Dear All.
Thanks for your responses.
Yes right English is not my first language so I'm very sorry about this inconvenience.
for the above case i mean there are 1 row tube for steam and 4 row tubes for hot water, both in one shell that air passed. Is this air heater can be classified as shell & tube Exchanger. Here i attached the sketch.
Thanks you.
Regard
Pimeng12
 http://files.engineering.com/getfile.aspx?folder=d5be76f8-ed5b-475b-9fe9-e35bc8b1740c&file=ec301.JPG
Actually, your English in the last post was impeccable. Thanks for the sketch.
A shell & tube Hx has a shell that completely encases the tubes, usually with a pressure rating that governs the shell thickness. The type of Hx that you have shown isn't usually thought of as a S&T type of Hx.
rmw
I'd be interested in seeing some details on the internals before I say yes or no. Heating air and water streams with a steam source in one device isn't something I've seen before and I wonder what the internals would look like.
Thanks for your opinion, I am pleased.
The heater was produced 1982 so there are no any complete detail available.
currently we are preparing required documents to order new one with some upgrading.
here i attached the arrangement of this heater.
Thanks for all.
Pimeng12
 http://files.engineering.com/getfile.aspx?folder=2e195025-ea12-432c-bc07-5279ef065c9a&file=51-EC-301.JPG
