alipourzand01
Aerospace
- Jan 31, 2007
- 5
Hello;
I'm testing an aerofoil in a wind tunnel to see the stall angle and effect of vortex generators.
1 - I'm using a NACA 6313 aerofoil, when testing it in my company's low-speed when tunnel (when it's plain i.e. no VG's on it) at low air velocity (25 m/s) the aerofoil stall at 13 degrees angle of attack which seems correct however when increasing the air velocity to 45 m/s the aerofoil doesn't stall untill 18 degrees AoA.
I know that the stall angle is not dependent on the air velocity so can anyone think of anything that could explain this behaviour.
2- The second issue I've got is with lower air velocity. As the aerofoil stall, at 15 degrees AoA onwards the lift start increasing again (with a very small margin), based on my understanding after the stall the lift should keep decreasing. what could be the reason for this?
PS1: All test have been done multiple times to ensure the accuracy and same result came out in both cases.
PS2: The wind tunnel is designed for automotive engineers and the software that output the data is specifically written for automotive engineers. But I'm not sure HOW it could effect my results.
Any help is highly appreciated.
Ali
Ali
