MJCronin
- Apr 9, 2001
- 5,087
GE PERFORMING HYDROGEN ENGINE TESTING IN THE EURO AEROSPACE INDUSTRY:
"The European aircraft manufacturer is partnering with aero-engine maker CFM International, the long-established joint venture between GE Aviation and Safran Aircraft Engines to provide the first engine for the program.CFM is to modify a GE Passport turbofan engine to run off hydrogen, while Airbus is configuring MSN1 A380, the first ever A380 built to carry the engine on a support at the top rear right of its fuselage."
WOW !!!!!
There is a lot of research money involved here... Structural conversion of an A380 into a test bed will not be cheap
What do you think of this ?
MJCronin
Sr. Process Engineer
WOW !!!!!
MJCronin
