haynewp
- Dec 13, 2000
- 2,327
In the 13th Manual on page 6-5, there are beam-column selection tables based on Section H of the specification. It also describes the use of these tables on pages 6-3 and 6-4 by plugging directly into the H1 equations and checking versus unity.
What I don't see is any mention of applying the B1 amplifier according to Chapter C, or some other method of including second order effects between brace points. The comments on pages 6-3 and 6-4 basically say just check the H1 equations and that is it. I could see ignoring second order effects if the Pc/Pr ratio is low, but the comments to the tables also mention using the table values directly when Pc/Pr > 0.2.
