I'm doing some checks to size transverse web stiffeners for a wide flange beam. I was hoping to get some clarification on the web sidesway buckling check. Specifically, I am looking at Cr factor. AISC directs you to select a Cr factor based on the ratio 1.5Ma to My. I can't find a definition for My anywhere.
Is this intended to be a yielding moment? Would this be the plastic moment or should it be calculated with an elastic section modulus?
Is the "y" intended to indicate the weak axis of the beam (i.e. some measure of when the beam kicks out sideways)?
Something else entirely?
