dik
- Apr 13, 2001
- 26,037
Does the AISC reduce the capacity of a tension member with bolted connections based on the length of the bolted part. For example if the tension member bolted part is 20" long compared to one that is 10" long. This might reflect the 'flow' of the load from the loaded end to the 'dead' end.
Thanks, Dik
Thanks, Dik
