Deener
- Aug 30, 2018
- 49
Hey guys,
I'm designing a simple frame. Each connection is designed as a full moment connection. I have checked all of the cases for which stiffeners may be required and it appears they are not (J10.1 to J10.9). Deformations in the frame are to be kept to a minimum. I would imagine that adding stiffeners to the columns and beams would reduce deflection. The issue with that manifests when designing the welds. AISC simplifies this process by stating the welds in the stiffeners should be sized to resist a force which is based on the difference between the required strength and the available strength of the unstiffened member. If no stiffeners are required, this is of course negative as the required strength is less than the available strength. Has anyone come across this circumstance before? I see a couple solutions.
1) Assume stiffeners don't contribute much to the stiffness of the connection if the specification dictates they are not required so don't use them. (I don't like to assume)
2) Attempt to calculate the deflection of the flanges and see how this effects rotation at the connection. I would likely model the flanges as a cantilevered beam with an end load to be conservative.
3) Simply specify the minimum weld size based on the thickness of the stiffener plates.
Thanks in advance for your input.
